Nothing transforms the appearance of your rig quite like an aftermarket bumper. Whether you prefer tube or plate construction (or even a combination of both) the benefits go well beyond aesthetics. The addition of a well engineered front bumper not only protects vital components such as radiators and oil coolers in the event of a crash, it can also provide recovery points, winch mounting solutions, and tabs for auxiliary lights and antennas for communication on the trail.
There are at least a squillion companies producing countless front bumpers in the aftermarket. We have gathered together several popular brands here that produce bumpers for a multitude of your favorite overlanding platforms. We outlined these bumpers in alphabetical order below.
It should be noted that due to space limitations, not all bumpers from every manufacturer could be listed; in other words, this is an extensive list, but is by no means all inclusive.
Is a front bumper/bull bar necessary for backcountry travel? The short answer is, no. Having stated this, it is highly recommended. Here is why:
- A proper front bumper helps protect your vehicle in the event of an animal strike and can minimize damage in such an event -in many cases, you can drive away from what may have been a total loss. Wild animals such as deer, goats, bighorn sheep and (unfortunately) dogs may dart into your path with little or no warning.
- Accidents happen, with a bull bar, the damage received during an on road automobile accident can be greatly reduced -reducing the cost of repair and downtime from your adventure. Accidents off road are more likely, wet conditions and off camber trails can cause vehicles to slide into trees and rocks causing broken lights, punctured heat exchangers, and body damage. A strong steel or aluminum bumper can lessen or eliminate damage altogether.
- Recovery is greatly improved with the use of a well equipped bull bar. Not only do they provide recovery points, many come with provisions for electric winches. Winches can be used to clear roads, right a tipped vehicle or recover a stuck vehicle.
- Mounting of peripheral devices such as light tabs, antennas, and in some cases, Hi-lift jack lift points are also advantages of having a bull bar. Fitting your bull bar with aftermarket lights adds a margin of safety during night driving. Although not street legal, this lighting can provide visual warning of upcoming ruts or washed out trails.
The bumpers listed in this Buyer’s Guide vary in engineering and construction vastly. For example, some have been DOT crash tested, but most have not. AEV and ARB are the only manufacturers to maintain the manufacturer’s low speed impact SRS system on all their bumpers. Details such as these are available in further detail from the specific bumper manufacturer. Ultimately, it is up to you to choose which features best fit your needs.
Although, we will try to keep this list up to date, product lines are constantly changing. If we get something wrong, let us know and we will be glad to change it. Did we miss a critical bumper? Be sure to let us know and we will add it.
Aluminess
Aluminess produces a breadth of bumpers for a myriad of different platforms. Below is their reasoning for producing their bumpers from aluminum rather than the more traditional steel construction adopted by most companies:
“Our aluminum products are designed for strength and utility, providing additional protection for your vehicle. The lighter weight allows you to get full performance out of your suspension and prevents wear and tear on your alignment, brakes, and tires. In addition, you don’t have to worry about rust!” -Aluminess
Aluminess: Ford Van Front Winch Bumper
Available for Ford Vans from 1992-Current.
*Weight varies by model and model year.
Price:
$2150 as pictured
Features:
-Winch compatible up to Warn 12,000 lb or 16.5ti
-Lockable storage compartment (in absence of winch)
-Accepts D-ring shackles up to ⅞” pin
-Optional receiver, cross-bars.
-Auxiliary light mounts
-Light weight construction
Materials:
-Aluminum
Weight:
-85 lbs
Additional images and information may be found here
Aluminess: Ford Super Duty
Available for Ford Super Duty 1999-2014, and 1999-2015 Ford Excursion.
Price:
$2150 as pictured
Features:
-Winch compatible up to 16.5ti
-Optional 8.5 ton shackles
Materials:
-Aluminum
Aluminess: Dodge RAM Winch Bumper
Available for 2003-2014 Dodge Ram and 2006-2014 Dodge Powerwagon.
Price:
$2150 as pictured
Features:
-Winch compatible
-Optional brush guards
-Optional receiver hitch
Materials:
-Aluminum
Weight:
-10 lbs over stock bumper
Aluminess: Toyota Tacoma Winch Bumper
Available for 2001-2015 Toyota Tacoma; 2007-2013 Toyota Tundra; 2007-2014 Toyota FJ Cruiser.
Price:
$1295 as pictured.
Features:
-Airbag compatible
Materials:
Aluminum
Weight:
-70 lbs
Aluminess: Chevrolet Van Winch Bumper
Available for 2003-2015 Chevrolet Vans.
Price:
$2150 as pictured
Features:
-Winch compatible Warn M12000 or 16.5ti
-Accepts D-ring shackle up to ⅞” pin
-Optional receiver mount
Materials:
-Aluminum
Aluminess: Chevrolet Silverado
Available 2003-2014 Chevrolet Silverado.
Price:
$2150 as pictured
Features:
-Winch compartment
-Integrated tow hooks
Materials:
-Aluminum
Aluminess: Mercedes Sprinter Van
Available for 2003-Current Mercedes Sprinter Vans.
Price:
$2150
Features:
-Winch compatible
-Optional 8.5 ton receiver hitch
-Auxiliary light compatible
Materials:
-Aluminum
Weight:
-90 lbs
Aluminess: Nissan NV Winch Bumper
Available for 2011-2015 Nissan NV 2500/3500.
Price:
$2150
Features:
-Winch compatible
-Storage
Materials:
-Aluminum
Weight:
-85 lbs
Aluminess: Mitsubishi Fuso Winch Bumper
Available for 2012-Current Mitsubishi Fuso.
Price:
$2400
Features:
-Winch compatible
Materials:
-Aluminum
Weight:
-85 lbs
American Expedition Vehicles AEV
“We strive to bring OE (Original Equipment)-level design, engineering and manufacturing to the aftermarket…We work closely with Jeep on both show cars and special edition versions, like the “Call of Duty” edition that came direct from the factory with our Front and Rear Bumpers and a special version of our stamped steel Hood.” -AEV
AEV has carried their expertise over to the fullsize truck market with their relatively new line of Ram 2500 / 3500 components including bumpers.
AEV: Premium
Available for 2010 Ram 2500 / 3500 trucks.
Price:
$2300 as pictured
Features:
-E coat, polyester textured black powder coating
-Made in the USA
-Accommodates up to 16,000 lb winch
-Heavy duty ductile iron tow loops
-Two optional 6.7” AEV/Vision X fog light kits available (1800 lumen halogen or 3200 lumen LED)
-Airbag compatible
Materials:
-4 mm stamped steel face; 3/16” steel reinforcement; ¼” winch mount
Weight:
-250 lbs
AEV: JK Premium
Price:
$1300
Features:
-Factory fog light mounts
-Decorative stainless steel mesh
-Airbag crush cans (airbag compatible)
-Optional winch mount
-Optional skid plate
-2 stage paint process
-Polyester textured black powder coat finish
-Reinforced flat area on underside for Hi-lift jack
-½” steel, chassis mounted tow points
-Max approach angle fits 37” tires with no rubbing
-Fits most low mount planetary winches
Materials:
-Stamped steel
AEV: JK Tubeless
Price: $1215
Features:
Materials:
-Stamped steel
ARB
“The harsh conditions of the Australian Outback are extremely demanding, and standard brush guards and grille guards simply aren’t strong enough to survive. For this reason, ARB pioneered the bull bar, designed specifically for maximum strength and reliability, to last in these tough conditions. And after years spent modifying and refining this design, the ARB bull bar is the most highly regarded 4×4 frontal protection system in the world.” -ARB
ARB: Sahara Bar
Pictured on 2003-2004 Land Rover Discovery II
Price:
$1473
Features:
-Airbag approved
-Recessed indicators
-Retains OE foglamps
-Grey powder coat
-Retains OE tow points
-Light mounts
Materials:
-.01 steel tubing and plate steel
-Antenna mounts
ARB: Summit Bar
Available for 2016 Toyota Tacoma.
Price:
$1600
Features:
-Incorporates ARB’s renowned multi fold upswept and tapered wing design for optimum strength and approach angle.
-30 mm radius on wings and center section for high clearance
-Airbag approved
-Twin Hi-Lift jack points
-Included ARB fog lights
-Mounting provisions for additional lighting
-Two antenna brackets
-Zinc rich primer and powder coat
-170 lbs
Materials:
ARB: Deluxe Bull Bar
Pictured on 2007-2013 Toyota Tundra.
Price:
$1800
Features:
-Airbag approved
-Grey powder coat
-Light mounts
-Antenna mounts
Materials:
ARB: Modular
Available for most late model, domestic full size Ford, Chevrolet, and Dodge trucks.
Price:
$2620 as pictured
Features:
-Airbag approved
-3 distinctive configurations available
-Press formed fog light housings
-Accommodate up to Warn 16.5ti winches
-Twin Hi-Lift jack lift points
-Fog lights are included
-Provisions for auxiliary lights
-Two antenna brackets at far end of wings
Materials:
-Steel construction
All-Pro
All-Pro has been in business since 1996 and has been popular in the rock crawling industry. While developing bumpers for the rigors of tackling boulders, the company has learned how to create tough, quality bumpers. The Apex bumper (pictured below) carries this quality into other sectors such as backcountry travel.
All-Pro: Apex
Pictured on 2005-2015 Toyota Tacoma.
Available: 1995-2004 Tacoma, late model FJ Cruiser,
Price:
Steel $979; Aluminum $1399
Features:
Steel Version
-Mounting brackets with frame gussets
-Heavy duty winch mount
-Two, 1” thick heavy duty recovery points
-Compatible with remote shock reservoir mounts
-Two, 4” fog light mounts
-Tubing is ½” .120 steel
-Airbag compatible
Materials:
-One piece 3/16” steel construction
Weight:
-149 lbs as shown
All-Pro: Tube
Pictured on1984-1994 Toyota 4-Runner.
Also available for 1979-1995 Toyota Pickup Truck.
Price:
$399 and up
Features:
-3/16” winch mounting plate
-Bolts to factory location
-Recovery attachment point
-Compatible with most winches up to 9,5
-Optional dimple die fill plates for strength and appearance
-Low profile design
-Maximum approach angle
-With or without stinger
-Made in the USA
Materials:
-1.75” x .120 wall tubing -steel
Bestop
Bestop has been producing some of the highest quality replacement tops for Jeeps for decades. The company now boasts a laundry list of aftermarket components, including steel plate bumpers.
Bestop: Full Width Winch Bumper
Available for 1989-Current Jeep Wrangler (YJ/TJ/JK).
*Also available in mid width configuration.
Price:
$509.99 as pictured
Features:
-Winch compatible
-High clearance wings
-Black powder coat finish
-Two D-ring attachments
-No drill installation
-Airbag compatible (low impact only)
Materials:
-3/16” steel plate
Buckstop Truckware
Buckstop is based in central Oregon and produces bumpers designed to serve both the recreational and commercial crowds. Their products are all made 100% in house from metal bending to powder coat, and each can be customized to the preferences of the buyer. From the first simple bumper in 1994, to the range of products offered today, their team aims to make versatile high quality products to serve their owners for years to come.
Buckstop Truckware: Classic I
“The Buckstop Classic model bumpers are the mainstay of the product line. An elegant clean look with full protection for the grill and headlights that includes plenty of beef with 2″ tubing over the headlights and 2-1/2″ tubing across the center. Buckstop Grill Guard tubing is located in front of the headlight corners for maximum protection.”
The Classic I series bumper is available for a wide selection of makes and models
Price:
$1,349 – $2,799
Features:
– Hidden winch mount
– Winch access cover door
– Recessed Light Mounts for one pair of 6″ lights
– 2″ Trailer receiver
– Tow hooks or relocation points for OEM hooks
– License plate mount
– Air inlets – especially for diesel cooling
– Black Hammertone Powder coat finish
– Hardware Kit and Installation Instructions
– Includes everything necessary to bolt-on and go
Materials:
-Steel
– Aluminum
– Stainless Steel
Weight:
Approximately 190 lbs depending on application
Buckstop Truckware: Classic II
The Classic II series bumper is available for a wide selection of makes and models
Price:
$1,949 – $2,049
Features:
Materials:
-Steel
– Stainless Steel
Weight:
Buckstop Truckware: Baja
“The Buckstop Baja model bumper is a sporty alternative that offers protection for the grill and headlights and includes plenty of beef with 2″ tubing over the headlights and 2-1/2″ tubing in the center. Buckstop Grill Guard tubing is located in front of the headlight corners for maximum protection.”
The Baja series bumper is available for a wide selection of makes and models
Price:
$1,499 – $2,199
Features:
Materials:
-Steel
– Stainless Steel
– Aluminum
Weight:
Buckstop Truckware: Outback
“The Buckstop Outback model bumper is the strongest of the lot! They are set apart by a 2-1/2″ to 3″ wide fabricated upright section that wraps over the face of the bumper. Full protection for the grill and headlights that includes plenty of beef with 2″ tubing over the headlights and 2-1/2″ tubing across the center. Buckstop Grill Guard tubing is located in front of the headlight corners for maximum protection.”
The Outback series bumper is available for a wide selection of makes and models
Price:
$2,149 – $2,249
Features:
Materials:
-Steel
– Stainless Steel
– Aluminum
Weight:
Buckstop Truckware: Boss
“The Buckstop BOSS model bumper rules to roost with a bold, fabricated center section. The beefy 4″ diameter cross tube is designed for more than just looks – it’s all planted on the top of bumper with a 5″ x 6″ footprint for serious protection.”
The Boss series bumper is available for a wide selection of makes and models
Price:
$2,149 – $2,249
Features:
Materials:
-Steel
– Stainless Steel
– Aluminum
Weight:
Buckstop Truckware: No Grill
“For a clean look, Buckstop bumpers are offered without any Grill Guard tubing above the base bumper.”
The No Grill series bumper is available for a wide selection of makes and models
Price:
$1,149 – $2,149
Features:
Materials:
-Steel
– Stainless Steel
– Aluminum
Weight:
CBI Off Road Fab
“Over the years CBI Offroad has built many different custom bumpers and accessories for vehicles of every type. Whether it is work vehicles, recreational or even power sports we can take care of your needs. Each bumper is built from the highest quality materials and hand crafted by the best fabricators and welders in the business.” -CBI
CBI Off Road Fab: Winch Bumper
Price:
$1473.99 as pictured (price includes Warn M8000 winch)
Features:
-Winch compatible
-Recessed winch mount
-Steel tube grill guard
-Black powder coat
-Twp D-ring tabs
Materials:
-Steel
CBI Off Road Fab: Moab Winch Bumper
Available for 1996-2004 and 2005-2015 Toyota Tacoma.
Price:
$1099.99 as pictured
Features:
-Mounts to frame rails
-¼” mounting brackets
-Fully mig welded
-Dual ¾” D-ring tabs
-Includes all mounting hardware
-License plate mount
-Optional powder coat
-Customizable
-Airbag compatible
Materials:
-3/16” steel plate
Weight:
-100 lbs
CBI Off Road Fab: T3 With Grill Protection
Price:
$1074.99 as pictured
Features:
-External mount for 20” LED light bar
-Winch compatible
-Increased approach angle
-Optional powder coating
-3.5 hour install time
-Airbag compatible
Materials:
-3/16” steel plate
-Aluminum option
Weight:
-130 lbs
CBI Off Road Fab: T4R3 Winch Bumper
Available for 1996-2002 Toyota 4Runner.
Price:
$799.99
Features:-Optional powder coating
-Winch compatible
-Frame rail mount
-Mig welded
-7 gauge mounting brackets
-Mounting hardware included
-Airbag compatible
Materials:
-Steel plate and tubing
CBI Off Road Fab: 4th Gen 4Runner Winch Bumper
Available for 2003-2009 Toyota 4Runner.
Price:
$1024.99
Features:
-Dual ¾” D-ring shackle mounts
-Winch compatible up to 10,000 lbs
-Vents for heat exchanger airflow
Materials:
CBI Off Road Fab: 5th Gen 4Runner Winch Bumper
Available for 2010-2013 Toyota 4Runner.
Price:
$1099.99
Features:
-Winch compatible
-Airbag compatible
-Grill protection
-Fully mig welded
-Customizeable
-Hardware included
Materials:
-3/16” steel plate
-1 ¾” HREW steel tube (optional)
Weight:
-110-125 lbs
Demello Offroad
Demello Offroad produces both steel and aluminum bumper, rock sliders, and front bumpers. These services are available for the Toyota Tacoma, FJ Cruiser, and Tundra platforms. Demello Offroad: Rally Winch Bumper
Available for 2010-2014 Toyota FJ Cruiser.
Price:
$1425 as pictured
Features:
– Accommodates up to 12,000 lb winch
-Airbag compatible
-Accommodates Rigid Industries 6” single strip LED lights
-High approach angle
Materials:
-¼” steel frame mount, ⅛” steel plate skin
-1.75” diameter steel tubing
Weight:
-115 lbs
*Also available in aluminum: 55 lbs, ¼” winch plate and frame mount, 3/16 skin, 10,000 lb winch capacity
Demello Offroad: Aluminum Winch Bumper
Price:
$1600 as pictured
Features:
– Accommodates up to 10,000 lb winch
-Airbag compatible
Materials:
-Aluminum construction. ¼” winch and frame mount, 3/16” plate skin
Demello Offroad: Toyota Tundra Winch Bumper
Available for 2007-2013 Toyota Tundra
Price:
$1400 as pictured
Features:
-Airbag compatible
Materials:
-Steel construction. ¼” winch plate, 3/16” skeleton, ⅛” outer skin
Weight:
-146 lbs
Demello Offroad: Three Hoop Front Bumper
Available for 2003-2016 Toyota 4Runner; 2005-2015 Toyota Tacoma; 2010-2014 Toyota FJ Cruiser.
Price:
$1225 as pictured
Features:
-Airbag compatible
Materials:
-Steel construction. ¼” winch plate, ⅛” outer skin
Demello Offroad: Single Hoop Winch Bumper
Available for 2003-2009 Toyota 4Runner, and 2012-2014 Toyota Tacoma.
Price:
$1175 as pictured
Features:
-Airbag compatible
Materials:
Expedition One
“Expedition One was founded in 2004 as a design and research company setup to develop innovative off road equipment …Expedition One is a focus-driven company, specializing in body armor …and recovery gear and equipment.” -Expedition One
Expedition One: Trail Series Winch Bumper
Available for 2007+ Jeep JK.
Price:
$1154.99 as pictured
Features:
-1” thick integrated D-ring shackle mounts for ¾” shackle
-High lift jack points
-Airbag compatible (high impact only)
-Auxiliary light mounts up to 7”
Materials:
-Steel plate
-0.120 steel tubing
Expedition One: Range Max
Available for 2007-2013 Toyota Tundra; 2016+ Toyota Tacoma.
Price:
$1784 as pictured
Features:
-Winch compatible
-Center hoop included
-Fits most winches from 8,000-12,500 lbs
-Three auxiliary light mount tabs
-Integrated light ports for up to 4.75”
-Sensor holes
Materials:
-3/16” and ¼”steel plate inner structure; 3/16” outer structure
Weight:
-150 lbs
Available for 2010-2014 Toyota FJC.
*6 Variants of FJC bumpers are available.
Price:
$1424.99 as pictured
Features:
-Airbag compatible
-1” recovery shackle mounts
Materials:
-3/16” steel plate internal structure, ⅛” steel plate outer structure
-0.120 steel tubing
Weight:
-120 lbs
Expedition One: Range Max Winch Bumper
Available for 2007+ 2500/3500 Chevrolet Pickup.
Price:
$1729.99 as pictured
Features:
-Winch compatible from 8,000-16,500 lbs
-Integrated 1” shackle mounts
-Sensor holes
-Optional center hoop
Materials:
-3/16” steel plate inner/outer structure
Weight:
-150 lbs
Fab Fours
“Fab Fours’ was born out of a passion for customizing vehicles and a love of the outdoors…”. Their products range from mild to the extreme, but all are created with the same care and attention to detail. Fab Fours offers armor solutions for Chevrolet, Dodge, Ford, GMC, Jeep, Nissan, and Toyota.
Fab Fours: Premium Bumper
Pictured on 2015-2016.
Also available for 2007-2016 Chevrolet 1500; 2007.5-2016 2500/3500; 2007-2014 Suburban/Tahoe; 2009-2016 Dodge Ram 1500; 1994-2016 Dodge 2500/3500; 2009-2016 Ford F150; 2010-2015 Ford Raptor; 1999-2016 Ford 2500/3500 Super Duty; 2004-2014 Nissan Titan; 2007-2016 Toyota Tundra; 2005-2016 Toyota Tacoma; 2007-2014 Toyota FJC.
Price:
$1237 for listed bumper (other variants available at different price points)
Features:
-2 stage black fder coated finish
-Accepts up to 10,000 lb winch
-Two, ⅞” D-ring mounts
-Injection molded light housings; fog and turn signals included
Materials:
-3/16” steel construction
Weight:
-160 lbs
Fab Fours: HD Elite
Pictured on 2015-2016 Chevrolet 2500-3500 HD.
Also available for 2007-2016 Chevrolet 1500; 2007.5-2016 2500/3500; 2007-2014 Suburban/Tahoe; 2009-2016 Dodge Ram 1500; 1994-2016 Dodge 2500/3500; 2009-2016 Ford F150; 1999-2016 Ford 2500/3500 Super Duty; 2004-2014 Nissan Titan; 2007-2016 Toyota Tundra; 2005-2016.
Price:
$1644.95 for listed bumper (other variants available at different price points)
Features:
-2 stage matte black powder coat
-Tow hooks
-Accepts factory lights
-Optional mount for 16,500 lb winch
-Optional: D-ring mounts; 2” receiver
Materials:
-12 gauge steel construction
Weight:
-200 lbs
Fab Fours: Jeep JK Full Metal Jacket
Available for 2007-2015 Jeep JK.
Price:
$1694 as pictured [$890 (bumper); $804 (grill guard)]
Features:
-Accepts 2×2 Rigid Industries Dually lights or factory fogs
-Winch mountable
Materials:
Weight:
-96 lbs (bumper only)
Fab Fours: Toyota Tacoma Vengeance
Pictured on 2012-2016 Toyota Tacoma.
Also available for 2014-2016 Chevrolet 1500; 2015-2016 Chevrolet 2500/3500; 2013-2015 Dodge Ram 1500; 2010-2016 Dodge 2500/3500; 2009-2016 Ford F150; 2010-2014 Ford Raptor; 2011-2015 Ford 2500/3500 Super Duty; 2007-2016 Jeep JK; 2012-2016 Toyota Tacoma; 2014-2016 Toyota Tundra.
Price:
$1247.39 for listed bumper (other variants available at different price points)
Features:
-2 stage black powder coat
-Integrated 20” light bar mount
-Mounting solutions for 2 2×2 Rigid Industries Dually lights
-Airbag compatible
Materials:
-11 gauge steel construction
Weight:
-75 lbs as pictured
Front Runner
Front Runner provides solutions for a multitude of off road, Overlanding purposes. From cooking, sleeping quarters, to storage solutions, Front Runner has you covered for nearly every aspect of your journey.
Front Runner: Detachable Front Bumper
Available for Mercedes Gelandewagen 461 and Pro.
Price:
$1550
Features:
-Winch compatible up to Warn 9000i
-Removable bull bar
-Black powder coat
-Bolted to vehicle using existing holes
-Installs in approximately one hour
Materials:
-Steel plate and tube
JCR Offroad
“Armor for Jeeps, Handmade in the USA”. This mission statement is what guides JCR Offroad to innovate and create a multitude of high quality products for Jeeps. All JCR products are made in America using American steel and hardware by a team of highly skilled craftsmen. Their extensive line of handmade bumpers show their commitment to quality and purpose.
JCR Offroad: Vanguard Full Width Bumper
Pictured on Jeep JK.
Also available for TJ/LJ/YJ/CJ7.
Price:
$999.99
Features:
-Fully welded steel tube grill guard
-Integrated Hi-Lift jack points
-Sunken winch mount
-D-ring shackle mounts
-Adjustable fairlead mount
Materials:
Weight:
-75 lb shipping weight -free shipping
JCR Offroad: Vanguard PreRunner
Available for 1984-2001 Jeep Cherokee.
Price:
$749
Features:
-Includes (2) 3/4″ thick shackle tabs
-Recessed Winch Mount
-Winch ready using the market standard 10″ x 4.5″ bottom foot mounting profile
-Compatible with the Warn Zeon and Warn Powerplant winches
-Accepts aftermarket 3×3 LED Cube Lights
-Built in Hi-Lift Jacking points
-High clearance profile
-powder coat additional $150
Materials:
-CNC cut and formed from 3/16″ Steel
Metal-Tech
Metal-Tech staff can be found in the back roads of their hometown in Portland, Oregon. After creating their first tube bumper, they began to realize that their needs were shared by others in the off road community – Metal-Tech was born soon after.
Metal-Tech: Tube Bumper with Bash Plate
Pictured on Toyota FJ Cruiser.
Also available for 2003-3009 4-Runner and Toyota FZJ80.
Price:
$949.99
Features:
-¼” cold rolled steel bash plate (with winch removed)
-Winch plate is removable with hand tools in 30 – 45 minutes
-4 light tabs for auxiliary lighting
-Airbag compatible
Materials:
-1 ¾” .120 steel tube construction
Weight:
-Weighs approximately 19 lbs more than stock bumper
Metal-Tech: 4-Runner Front Winch Bumper
Available for 2014 Toyota 4-Runner only.
Price:
$1449 – $1896 (Stage 1 – Stage 3)
Features:
-Hidden winch mount
-Lower stone guard
-Recessed mounts for LED fog lamps
-Fog lights wire directly to factory harness
-30” LED light opening (grill insert available to delete this option)
-¾” D-ring shackle recovery points
-Airbag compatible
Materials:
-CAD designed; powder coated steel
Weight:
-68 lbs heavier than stock bumper
Metal-Tech: Toyota Tacoma Front Winch Bumper
Available for 2016 Toyota Tacoma only.
Price:
$1399 – $1897 (Stage 1 – Stage 3)
Features:
-Hidden winch mount
-Optional bolt on grill hoop
-Airbag compatible
Materials:
-CAD designed; powder coated steel; multiple gauges of steel used
Weight:
-100 lbs heavier than stock bumper
Metal-Tech: Lexus GX470 Front Winch Bumper
Available for 2003-2009 Lexus GX470 only.
Price:
$1499 – $1973 (Stage 1 – Stage 3)
Features:
-25” LED light bar opening (grill insert available to delete this option)
-DOM-SRA bolt on steel tube grill guard
-Hidden winch mount
-Airbag compatible
Materials:
-Powder coated steel plate construction
Poison Spyder
Poison Spyder is well known in the rock crawler community. Their products are touted for their high quality as well as tough construction. Their full width bumpers provide excellent protection for both on highway and backcountry travel.
Poison Spyder: JK Brawler Full Width w/ Brawler Bar
Available for Jeep JK.
Price:
$749
Features:
-Winch compatible
-Recessed light mounts
-Dual D-ring shackle mounts
-Clearance for up to 37” tire
-Welded bull bar
Materials:
-3/16” CNC cut plate steel construction
Pronghorn
“All Pronghorn components are designed and manufactured in the USA and we have adopted the best manufacturing technologies to make sure we get the best parts” -Pronghorn
Pronghorn: JK Front Bumper
Price:
$1290 – $1890 (Depending on configuration); flat rate shipping only $75
Features:
-Optional upper portions are constructed of ¼” 6061-T6 aluminum
-Fully boxed construction
-18 different configurations available
-Hi-Lift jack lift points and available mounts
-Winch compatible
-Rotator shackle, D-ring shackle, tow hook mounting options
-Nine integrated light mounting locations
-Stage 2 and 3 powder coating
-Front bumper skid plate
Materials:
-Fully boxed, tig welded 3/16” 6061-T6 aluminum construction
Weight:
-Weighs as little as 42 lbs (19kg) in base configuration
Pronghorn: Toyota Tacoma
Price:
$1640 – $2390 (Depending on configuration)
Features:
-5 different configurations available
-Optional bull bar and headlight protection
-Winch compatible
-Traction cleats
-Airbag compatible
Materials:
-6061-T6 aluminum construction
Weight:
-73 lbs (33.1 kg) in base configuration
Reunel
“Reunel manufacturing has been producing the highest quality extreme heavy duty winch bumpers since 1987. The reunel front winch bumper is the strongest and most attractive premium welded steel bumper available. Reunel winch bumpers are sold to a variety of industries and consumers, including county, state and federal agencies. Reunel heavy duty winch bumpers are available in polished mirror-finished stainless steel or dupont automotive painted mild steel.” -Reunel
Reunel: Ford Winch Bumper
Available for: Ford Super Duty 1999-2011; Ford Excursion 1999-2011; Ford Expedition 2001-2011; Ford F150 1997-1998, 2001-2011; Ford F350 1999-2006, Ford Bronco 1978-2000
Price:
$1650-$2350 w/guards
Features:
-Winch compatibility: Warn Powerplant, Warn xd 9000; Warn xd 9000i; Warn 9.5ti Warn m15000; Warn 16.5ti.
-Dupont automotive paint or polished (stainless) finish
-Auxiliary light provisions
-Fully encased winch mount
-Heavy duty grill guard
Materials:
-Steel plate
-304 stainless steel
Reunel: Chevrolet Winch Bumper
Available for: 1989-2011 Chevrolet trucks
Price:
Features:
Materials:
-Steel plate
Ruenel: Dodge Winch Bumper
Available for: Dodge Ram 2003-2011; Dodge Sport 1999-2011; Dodge 1973-1998.
Price:
Features:
Materials:
-Steel plate
Road Armor
“At Road Armor we pride ourselves in building the ultimate replacement bumper. A bumper that adds utility and function to your vehicle while simultaneously making it a safer place for its occupants. Even our rear bumpers are designed to hold a winch. We receive testimonials regulary from grateful customers whose lives they believe were spared thanks to our bumpers, and first responders who see these kinds of accidents every day and know what the alternative looks like. Road Armor bumpers are battle proven and trusted by the United States and allied forces. That’s why we say “Rule the Road”, because with Road Armor replacement front and rear bumpers, your truck or jeep is transformed into a warrior poised to protect and prepared to defend.” -Road Armor
Road Armor offers three to four standard bumpers for most popular pickup trucks (Toyota FJC included) and two full width front bumpers for the Jeep JK. All Toyota and Jeep JK bumpers are airbag (SRS) compatible.
Road Armor: Titan
Available for 2008-2013 Chevrolet 1500; 2003-2015 Chevrolet 2500/3500; 2003-2009 Chevrolet 4500/5500; 1994-2008 Dodge 1500; 1994-2010 Dodge 2500/3500; 2006-2010 Dodge 4500/5500; 2009-2014 Ford F150; 1999-2004 Ford Excursion
Price:
$2699
Features:
-Winch compatible up to 12,000 lbs
-5 stage powder coating
-Recessed light pods
Materials:
-3/16” outer shell, ¼” internal shell
-0.120 DOM tubing
Road Armor: Stealth Series
Available for 2010-2016 Ford Raptor.
Price:
$1899
Features:
-Light pods for Rigid D series lights; two 6” Rigid LED light bars
-Winch compatible up to Superwinch Talon 12.5 SR
Materials:
-3/16” steel plate outer, ¼” steel plate inner
-0.120 steel tubing
Road Armor: Black Stealth Winch Bumper
Available for 2007-Present Jeep JK.
Price:
$1599.95
Features:
-Fits Warn Powerplant winch
-One piece welded design
-Provisions for 20” LED light bar and four auxiliary lights
-Dual 7/8 “ shackle mounts
-¼” frame mounts
Materials:
-3/16” steel plate
-0.120 steel tubing
Shrockworks
“At ShrockWorks, dueling with Mother Nature off the pavement is our passion. It’s a ton of fun, but she is often a very formidable adversary… Our goal is to ensure you get through the trail with your truck in one piece, without making it look like a tank someone made in a high school shop class.
…Only the best and strongest materials are selected for each product. However, that does not mean simply building every product from 200 lbs of steel. All ShrockWorks products are designed to have a very high strength-to-weight ratio.
We combine old world craftsmanship with the very latest in Computer Aided Design and manufacturing to produce each product. Most parts are cut by computer controlled lasers or high definition plasma systems, then welded and hand finished by skilled craftsmen.
We take great pride in every product we ship. Many hours of research and development go into the design of every ShrockWorks product to ensure you a simple installation, a great fit and a product of unequaled quality and durability.” -Shrockworks
Shrockworks: Winch Bumper
Available for 2005-2015 Nissan Xterra and Frontier; other versions are available for previous generations of the Nissan Xterra and Frontier.
Price:
$1049 as pictured
Features:
-Winch compatible up to 9,500 lbs
-1″ thick recovery points
-Integrated mounts for factory fog lights
-Includes radiator skid plate
-Frame brackets adjustable for a body lift
-Simple bolt-on installation
-Optional powder coat finish
-Several tubing options available including a low profile prerunner hoop
-Designed for 20″ Rigid E-series light bar (#120312)
Materials:
-3/16” steel plate exterior
-¼” steel plate interior
Available for 2010-2016 Toyota 4Runner.
Price:
$1397 as pictured
Features:
-Winch compatible to 9,500 lbs
-Factory fog light compatible
-2.5” turn signals
-1” thick recovery points
-Airbag compatible
Materials:
-3/16″ steel body & skids
-1/4″ mounting brackets
-2 ” and 1.5″ x 0.120″ wall high strength tubing (optional)
Weight:
-137 lbs
Available for 1996-2015 Toyota Tacoma; 2014-2016 Toyota Tundra. 2005-2015 Tacoma pictured above.
Price:
$1217
Features:
-Integrated mounts for Baja Designs Squadron lights
-Mounts for aftermarket lights on top of the bumper
-Standard aluminum skid plate
-Airbag compatible
Materials:
Available for 2007-2014 Toyota FJ Cruiser.
Price:
$1049
Features:
-Winch compatible
-Light mounts inside and on top of the bumper
-Aluminum front skid plate
-Airbag compatible
Materials:
Weight:
-110 lbs
Slee Off Road
“The Slee name has been recognized as a symbol of quality, strength and superior design. Our product range of bumpers, sliders, skids plates and other specialty pieces are unmatched. Our products have been tested on some of the most difficult trails in the United States.” -Slee
Slee Off Road: Short Bus
Available for 1991-1997 Toyota 80 Series Land Cruiser.
Price:
$989
Features:
-Winch compatible
-Dual D-ring shackle mounts extend to frame
-Airbag compatible
Materials:
-3/16 steel plate
-⅜” frame mount
-1.75” and 1.5” DOM tubing
Smittybilt
“Today, Smittybilt, Inc. proudly supplies thousands of active dealers and distributors worldwide with innovative truck and SUV accessories. Smittybilt has expanded its product offering to over 2,000 different products servicing the international truck and SUV markets. The constant involvement of management in the off-road markets has kept Smittybilt in touch with the latest market trends and on the forefront of engineering and design. Welcome to the new Smittybilt where innovation and quality are once again at the forefront of product development.” -Smittybilt
Smittybilt: SRC Gen2 Winch Bumper
Price:
$599.99
Features:
-Winch compatible up to 12,000 lb winch
-Dual D-ring recovery mounts
-UHMW plating for reduced friction on rocks
-Brush guard
– High clearance tube wings
-Factory fog light mount provisions
-Powder coating
Materials:
-2” diameter 0.120 steel tubing
-3/16” steel plate
Smittybilt: M1 Winch Bumper
Available for 2014-2016 Toyota Tundra; 2007-2014 Toyota FJ Cruiser; 2006-2012 Dodge Ram 2500/3500; 2008-2015 Chevrolet 2500/3500; 2014 Chevrolet 1500; 2008-2005 Ford F250/F350 Super Duty.
Price:
$1299.99 as pictured
Features:
-Winch compatible up to 16,500 lb winch
-Flush driving and fog light mounts
-Two stage powder coating
-Dual ⅞” D-ring mounts
Materials:
-1/4” mounting plates
Trailgear
“Trail-Gear first opened its doors back in 2005 with the goal to help out the average wheeler and get more people interested into rock crawling by providing high quality parts at a great price. We have since continued on with this goal and grew throughout the years, increasing our product line and warehouse space.” -Trailgear
Trailgear: Rock Defense Winch Bumper
Available for the 2007-2014 Toyota FJ Cruiser; 1995-20015 Toyota Tacoma; 1985-1995 Toyota 4Runner; 1984-1995 Toyota Pickup; Toyota FJ80 Land Cruiser.
Price:
$481.95
Features:
-Winch compatible up to 9,500 lb winch
-Receiver hitch
-Brush guard
-Also available without brush guard
Materials:
-1.75” 0.120 DOM tubing
Warn
Founded in 1948, Warn has been creating solutions for off roaders, military, and emergency rescue vehicle applications for decades. Known primarily for their winches, Warn also offers a full line of bumpers for both domestic trucks and Jeeps.
Warn: Ascent
Currently available for 2014 – 15 model year Ford F150; 2015 Super Duty F250 & F350; 2015 Ram 1500, 2500 & 3500; and 2015 Chevy Silverado 1500, 2500 & 3500
Price:
$1399.99
Features:
-Low inset winch mount, up to 12,000 lb Warn
-Provision for deep inset mount for flood and spot lights
-High clearance outer wings
Materials:
-11 gauge steel in textured black coating
Warn: HD
Current applications include most current model year domestic full size trucks.
Price:
$2599.99
Features:
-Optional tube grill / brush guard consists of large diameter welded steel tubing
-Winch ready, accepts up to Warn 16.5 ti
-High clearance outer wings adds room for oversized tires
-Commercial duty and fleet approved
-Integrated light ports with Warn W350F wireless fog lights and tabs for additional lighting
Materials:
-¼” and 3/16” welded steel construction with powder coat and undercoat
Warn: Elite Series
Currently available for the Jeep JK only.
Price:
$590 – $700
Features:
-Recessed light mounts and provisions for additional lighting
-Optional welded, steel tube grill guard
-Recessed jack points
Materials:
-Steel plate construction
Warn: Rock Crawler
Available for 1989-1995 Toyota Pickup.
*Excluded Toyota Tacoma.
Price:
$753.99
Features:
-Winches up to 9500 lb capacity
-Black powder coat
-Tapered wings for high clearance
-Wings extend to fender flares for increased protection and aesthetic
-Integrated factory turn signals
Materials:
-3/16” and ¼” steel plate
