New Sprinter-Compatible Method 901 Dually Wheels
Sprinter owners take note, Method Race Wheels, known for their high-performance products that promise to be “lighter, stronger, faster” has just released the 901 Sprinter dually. This matte- black front and rear wheelset is manufactured from solid A356 aluminum with T6 heat treatment construction.
The 901 Sprinter Dually has the iconic 12-window design, a bolt-on front center cap, and push-through rear center cap, both with embossed METHOD logos. The front and rear wheels have a 3,000-pound load rating, and according to METHOD, the “industry’s best lifetime structural warranty.”
**Aftermarket lug nuts and a valve stem extension kit are required for installation.
A full set of 901 Sprinter duallys in 16×5.5 with a 6×205 bolt pattern will set you back $1,294. Of course, if you don’t have a dually but still want some Method wheels, there are a handful of other Sprinter-compatible options including the following.
  • METHOD Race MR301 – A 10-spoke machined aluminum or satin black rim with push-through hub covers, removable stainless bolts around the lip, and the Method logo machined into one of the spokes. The MR301 will increase your track width with a 50-millimeter offset and is compatible with Method’s hub-centric spacer kit.
  • METHOD 701 – This 8-spoke design comes in black or bronze and is made from 356 aluminum and is T6 heat treated. METHOD’s bead grip technology ensures proper bead seat and reduces tire roll-off in low-air situations with reviewers confirming this functionality down to 10 psi.
  • METHOD MR305 NV – One of the higher-rated wheels that is Sprinter compatible, the MR 305 NV comes in silver, bronze, or black (all with a black lip). This 12-spoke design has a machined face and undercut outer lip. A machined Method logo surrounds the center wheel face and each wheel features a push-through hub cover center cap.
Check out the 901 Sprinter Dually on Method’s website.
