Built by Tactical Applications Vehicles, this 2018 supercharged Toyota Tundra with long-travel suspension screams comfort and off-pavement capability. Based on the TAV Stage 3 suspension system, the front consists of the Total Chaos Fabrication 2.5-inch long-travel system with secondary shock hoops, King 2.5-inch performance adjustable coilovers, and King 3.0-inch triple-bypass secondary shocks. TAV-spec Alcan progressive-rate leaf springs, a Total Chaos Fabrication rear shock relocation kit, and TAV-spec King 3.0-inch internal-bypass shocks round out the rear.
The Tundra is a spacious platform that provides the benefit of a flatbed conversion and, in this case, the addition of a FiftyTen camper. The camper is currently empty, which means potential buyers could outfit the interior as they see fit. For a closer look at the FiftyTen, read former Expedition Portal editor Chris Cordes’ thoughts in this article from 2019.
From Matt:
“This Tundra was built as a personal project for the owner of TAV and is one of the only long-travel supercharged Tundras with a FiftyTen camper that we know of. The sale of this vehicle will fund the next shop project.
The FiftyTen camper is a three-piece system consisting of the flatbed tray, the camper, and the front box, which contains the spare tire and storage. This system is currently empty but can be outfitted with custom cabinetry from Goose Gear.
Upon purchase of the Tundra, new tires will be mounted, and the vehicle will be fully serviced and tuned.”
Specifications
Total Chaos Plus 2.5-inch boxed long travel kit
Total Chaos weld-on spindle gussets
Total Chaos lower control arm tab gussets
Total Chaos 3/4-inch lift shackles
Total Chaos rear shock hoop kit (Tundra)
Total Chaos dual shock hoop/Tundra LT
RCV extended-length Tundra axles
King Shocks, Tundra 07+ long travel remote reservoir coilovers with adjusters, front 800-pound/in spring
King Shocks, Tundra 07+ long travel 3.0, three-tube external bypass shocks, front (1)
King Shocks, Tundra 3.0 IB resi with adjusters (1)
Archive Garage U-bolt Flip kit, Tundra w/bump stops
TAV Spec Alcan leaf springs
Nitro Gears, Tundra 5.29 dropout with ARB air locker (front)
Nitro Gears, Tundra 5.29 dropout with ARB air locker (rear)
ARB air locker activation compressor system
SPod wiring harness adapter for ARB compressor
Magnuson supercharger (Tundra 5.7-liter 07+)
Long Range Automotive Tundra DC SB replacement 46-gallon fuel tank
Prinsu, 2nd-Generation Toyota Tundra (2007-2018)
Prinsu noise reducer trim
Prinsu load panel
Prinsu tie-down rings
Alu-Cab LHS Shadow Awn
AT Overland awning brackets
Awning brackets spacers
AMP Research, 07-17 Tundra AMP76137-01A
FiftyTen USA large-size tent and tray
FiftyTen USA large-size cargo box and tire carrier
C4 – 2014+ Tundra Overland Series front bumper (full-height center bar)
ComeUp self-recovery winch (Seal Gen 2 12.5 RS)
RCI skid plate package | 07-Present Tundra, raw aluminum
Factor 55 ultra hook
SPod SE HD
Baja Designs LP6 Pro, LED, driving/combo (front bumper)
Baja Designs LP9 Pro, driving combo/white (front bumper)
Baja Designs wiring harness, LP9 Pro, two-light max
Baja Designs Squadron-R Pro, pair driving/combo, amber, fog lights
Baja Designs S1, flush mount wide cornering white (corner of front bumper)
Baja Designs rock light
Ravelco anti-theft device
Alpine Halo 11 and install kit
WeBoost Drive 4G-X OTR
Method Race Wheels 704 matte black
Toyo MT 37-inch tires
Located in Albuquerque, New Mexico, this 2018 Tundra is listed for sale for $186,000 and will be available in mid-December 20201. Check out the full vehicle specs via Tactical Application Vehicles’ website here.
